Assistance with PEQ Q
I am using TOA HX-5 for my mains. The manufacturer calls for the following EQ adjustments:
800Hz -3dB Q .7
2.5kHz -4dB Q 2.997
5kHz +5dB Q .305
With the specified widths I can't do exact in my Driverack PA, close but not exact. If I emulate the settings as per the manufacturer the curve looks quite different than what I can get to as close.
By close:
800Hz -3db Q .73
2.5kHz -4dB Q 2.63
5kHz +5dB Q .33
Is there any way by adjusting center frequencies, Q, different cuts, etc to attain the curve as specified or at least get closer to the effect of the first set of numbers I am unable to use exactly?
800Hz -3dB Q .7
2.5kHz -4dB Q 2.997
5kHz +5dB Q .305
By close:
800Hz -3db Q .73
2.5kHz -4dB Q 2.63
5kHz +5dB Q .33
