RCF SETTINGS
adrianadrian Posts: 6
Hi,everybody.
I have just received my pa+ and i think a little help is needed.
I am a dj for weddings and partys.(2xcdj400 and djm 600 from pioneer)
The speakers are selfpowered:
2x rcf Art 725-A
45hz-20khz
135 db
compression driver2"-2,5 voice coil
woofer-15"-3.5 voice coil
2xrcf subs-4Pro 8003 AS
40hz-120hz
134db
4" voice coil
I didn t found this speakers on dbx list.
Some help with settings would be great.
Thank you very much.
  • GadgetGadget Posts: 4,915
    I'd suggest you start with
    Subs
    HPF 35hz BW18
    LPF 100 hz LR24
    tops
    HPF 100hz LR24
  • DraDra Posts: 3,777
    I concur.
  • A good place to start is 100 hz for subs to mids. Sometimes its higher, sometimes lower. Its depends on what your power settings are and what size of speaker, but start at 100 hz and adjust from there, the xover type wont always be the same for every speaker, thats why there are differnt types, but start at 100 hz and adjust from there.
    One thing you can try is do several different preset settings for the pa and switch between them and see what is better.
  • adrianadrian Posts: 6
    Thank you for advice. I will try these settings then i contact for more if is needed.
