Rane RTA mic
Recommended for DRPA+? will results be different in any significant way?
Thank you,
a dude in Sutton, MA
Thank you,
The Rane RTA mic is an odd duck with a 1/4" connector and runs on a DC voltage...check out link. RaneNote 104 is obsolete and no longer on the Rane website. For a better view, save it to your computer.
http://www.findthatdoc.com/search-11205 ... 04-pdf.htm
You might make it work but you will need to do mods
RTA30 with MIC2:
Microphone Type Back-Electret Condenser 6 mm capsule
Frequency Response 20 to 16,000 1 dB +2 dB at 20 kHz
Polar Pattern Omnidirectional
Impedance 1.8k 5% Ω With 2.2 kΩ load
Sensitivity -44 ±3 dB re 0 dB=1V/Pa, 1 kHz
(6.3 mV @ 94 dB SPL) 1 Pa = 94 dB SPL
Maximum SPL 140 dB 1 kHz
Signal-to-Noise Ratio 58 (re 94 dB SPL) min dB 1 kHz, A-weighted
Phasing Non-inverting Positive diaphragm pressure equals positive output voltage
Power: Voltage Range 1.5 to 6 VDC T-power; absolute min and max ratings
..........Rated Voltage 2.0 10% VDC
..........Sensitivity Loss -3 dB @ 1.5 VDC
..........Current Demand 1 max mA @ 2.0 VDC
Cable 25 feet (7.6 meters) 2 conductor shielded; XLR-F to -M standard mic patch
Case 6" x 9" (15.2 cm x 22.9 cm) Zippered heavy black vinyl
Storage Temperature -20 to 60 ºC -4 to 140 ºF
Operating Temperature -18 to 50 ºC 0 to 122 ºF
Relative Humidity 0 to 95 % Operating or storage
ac
