RTA - excessive cuts & boosts in Auto EQ
Cover'd
Evening all
Have used a DriveRack PA for a number of years - primarily as a crossover and final limiter before an active PA
I currently use it full range (aside from a sharp sloped high pass at 40Hz) into QSC K-Subs and on to QSC K-10s (utilising the Ext Sub crossover option on the K-10s). I have a gentle PEQ curve presently applied (something like the 'classic wave' but only a 3bd lift in the lows, 3db cut around the mids and a 2db lift again in the highs). Am very happy with the sound, but do wonder if I might be missing out on some extra 'gold'..?
I have a dbx RTA mic, but haven't run the Auto EQ wizard on this particular system as yet. The reason for this is that in every previous RTA encounter, I've noticed -12db cuts and +12 boosts in random frequencies across the spectrum. Putting aside whether the resultant sound would have necessarily been good or bad, there's something about that degree of EQ which just strikes me as odd, or even, 'wrong'
So, are your thoughts or experiences with Auto EQ and the excessive cuts & boosts which can result..?
EDIT: Have just noticed the advice around the forum NOT to follow the manual
Hummm... I wonder if this could be the main contributing factor..?
If it were me I would also use the driverack for the crossover from subs to tops and NOT use the built in one...
Please take a look at the "Start here" and FAQ sections were we get into just how to PROPERLY do this...you may be surprised with the results...
Any specific reason why you recommend using the DRPA crossover rather than the QSC designed stuff..? I'm happy to go down either route, but I'm curious to know what advantages (other than being able to treat the dynamics of the lows & highs differently) there are to utilising the DRPA and steering clear of the built in system..?
I've had a read through the Start Here stuff and yes, most of it is familiar and certainly rings true - I do recall gleaning the 'EQ your system to a flat response, not the room' gem before
However, even in an Auto EQ test in a field on a previous Mackie SWA1801 & SR1521 system, I noticed the 12db cuts and boosts too. Are manufacturer's response graphs really hiding such peaks and troughs..? A few tweaks I can understand, but it's the extremity of them which make me wonder what the truth is...
Perhaps the acid test is always one's ears and as I mentioned, the rig does sound great, but we always like 'better', don't we..?
You said that you followed the instructions in the "Start here" thread for outdoor auto EQ? Your results seem odd, if that is the case. Too close, too far, too low, too high, buildings, concrete, wind, bird, cars, door slamming, something...
