Driverack px is it essential to use the rta mic.
Hi ive been reading the board for a few days and read the 'read me first' and q and A sections.
To cut a lobg story short i bought the PX because fellow artistes advised me to get one as they say it will cleanmy sound up and protect my speakers.
I am currently using lap top,backing tracks and 2 vocals. We use 2 RCF712a's and a 400watt powered Opera DB 15 inch bin.
My point is i tried using the pre-sets couldn't find my speakers listed so used custom. But when i got to the rta mic section i could go no further as i didn't get one in my sale.
I have now given the px to a local sound engineer who sets all the driveracks for local bands.
Can it be done this way without actually having the speakers????
Sorry if this is a dumb question but i am really crap with gadgets,etc....
Cheers for any help
Cheers for any help
ACOUSTICAL SPECIFICATIONS
Frequency response: 50 Hz- 20 Khz
Max SPL: 129 dB
Horizontal coverage angle: 90°
Vertical coverage angle: 60°
Compression driver: 1.0� neo, 44 mm voice coil
Midrange: -
Woofer: 12� neo, 76 mm voice coil
INPUT SECTION
Input signal (Impedance): bal/unbal
Input/Output connector: combo xlr-jack/xlr
Input sensitivity: + 4 dBU
PROCESSOR SECTION
Crossover frequencies: 1700 Hz
Protections: thermal, hf
Sensitivity control: yes
Limiter: fast limiter
High pass: -
Controls: flat/boost
AMPLIFIER
Power supply: switching 750 Watt
High frequencies: D / 250 Watt
Mid frequencies: -
Low frequencies: D / 500 Watt
Cooling: convenction/
Max SPL: 129 dB
Midrange: -
INPUT SECTION
PROCESSOR SECTION
High pass: -
AMPLIFIER
Mid frequencies: -
Specification
Variety
Active
Power Rating
400 Watts RMS
SPL
129 dB
Dispersion
N/A
Weight
31.8 Kg
Warranty
2 Years
Dimensions
(H) 515mm x (W) 490mm x (D) 610mm
Other
Wider frequency range than most of its contemporary units. 30 Hz - 150 Hz
Remember you will have to explain in 'idiot' mode because i'm not very good at stuff like this.
When i tried myself i set speakers to custom but got stuck when it said attach rta mic (i aint got one)
Once again thanks in advance
Gino
I really need someone to just advise me on how to do it,ie press set up,press etc,etc....
I watched a youtube video but like i say got stuck at the mic section
Cheers for any help
Gino
As Gadget said, all you need to do is set up your High and Low filter bands. Something like... (all set CUSTOM)
Low: 30hz BW18 - 100hz LR24
High: 100hz LR24 - OUT (It may not even offer any choice here)
The gain settings in the x-over/filter sections should be set to -0- to start and the speakers gain knobs should set to -0- as well (normally 12 o'clock). I like to play a CD (paused) with the mixer set at what you would typically would run it at, then adjust the gain knob on the speakers until the "hiss" is at an acceptable level. On my powered speakers it happens to be 11 o'clock.
Gino
The chap i was giving the drive rack to is not answering his phone so looks like i'm on my own with the help of you and Dra.
I will be getting it back tomorrow or sunday so plenty of time for your fingers to hurt by typing...lol
Once again i really appreciate everyones help
Gino
www.catseyesduo.co.uk
I am new hear too but have had a PX rack about 6 months and love it. I have about 18 venues saved in the rack and am constantly getting feedback from other musicians about how impressed they are with our sound.
I have a mixture of DB tech Opera mains and fold back speakers and Wharfedale subs. All my DB Tech speakers volume knobs are set to the 3 oclock position which corresponds to the 0 setting and my Wharfedale subs are set at 12 o'clock. Your subs sound similar in spec to mine and since having the PX I have never seen my speakers peak since once and we now have a better clean and punchy sound than pre PX (was happy before but happier now) The unit is also saving me so much time when we return to the venues we have already Pinked and saved.
I don't use the compression or limiting feature normally as I let the speakers handle that unless I am mixing for some young bands just in case things get a bit crazy.
I used the auto set up for a while but now I have it I bypass that and just set my DB tech tops to 3oclock and the subs to 12 o'clock and go and have a listen for the balance and once happy I turn off one side of the PA then run the Auto EQ option C medium response for most venues to the side of the PA that is still on. Once done I just store it and turn the side turned down back on. For most venues the auto EQ is good enough as normally I am pushed for time. I may do the odd tweak manually or sometimes use the some post EQ section to filter out and low frequencies that are dirtying things up a bit. The main setting I probably adjust the most is the sub output level to get the bottom end I want with the bass control on the desk back ground music channel set to near 0 and then just re-save the preset.
A lot on here do not like the auto EQ but I find it convenient and now I have saved a default set up which I reuse the Auto eq is much quicker. If there are people present I just explain there will be as bit of noise for 30 seconds or so and they seem happy with that - but don't do it with out a warning first
My saved default AFS settings haven't let us down, so that too is saving us time but channel EQ and mike placement help here to like with any PA set up.
My advice is to get an RTA mike and set your PA some where you can have it set up with out bothering any one and get your self confident with all it can do. It is the best money I have spent in a long time and means less gear to lug around too.
Sorry for delay but after 2 weeks the drive rack expert has finally got round to setting my px.
I got it back last night so tonight i will try it for the first time ,i havent a clue what he's done.
Gadge if theres anyway i can go through the settings and post them on here please let me know,then you can advise on if theyre what you would have used ?
Wish me well as i'm going in blind folded tonight,i'll plug in and hope for the best.
I will report back....over and out gang
Cheers Gino
Well plugged it in last night and went for it.
Wow blown away with clarity on top end.
Impressed that the bass bin never clipped.
Disapointed that seemed to get a bit of low/mid honking feed back.
Overall well and trully impressed.
Gino
Gino
Is it feeding back in the subs or the top cabs?
What are the x-over freqs used?
Gino
Gino
ps As i said in a previous post i'm not very technicaly gifted.
Do you have access (now) to your PX?
As i said was very impressed with overall sound it was just that feedback that put a dampner on the sound.
Gino
