PA+ with Jbl Eon 515xt , Qsc PLX 3102 & Cerwin Vega Ab36 sub
What's up guys?
I'm a DJ, and very new to this whole Driverack setup. Just purchased a PA+, and running:
2-JBL Eon 515xt
1-QSC PlX 3102
2- Cerwin Vega Ab36 subs
I was wondering what would be the correct configurations, or any suggestions, as far as:
-Xover
-Comp/Limiter
-Subharmonic Synth
-GEQ/PEQ
-Delay
2-JBL Eon 515xt
1-QSC PlX 3102
-Xover
-Comp/Limiter
-Subharmonic Synth
-GEQ/PEQ
-Delay
In a nutshell...
40hz BW18 - 100hz LR24
100hz LR24 - Out
Set the limiter as described in the Gain Structure thread.
Best NOT to use compression.
Best NOT to use Sub-Synth. Use at your own risk, but you may need the added low-end (fake).
For EQ, use follow the "flattening" techniques described using the RTA wizard.
Get an approximate measurement of the horn length (CW site may have the info for you, but doubt it) and delay the Eons 1ms for each foot (assuming that you are putting the Eons directly above the CVs) If not on top, the same holds true except you have to add or subtract the lateral distance.
