DRPA+ with EV DML-1122 and Turbosound TSE-118
Hey Everyone!
I have to build up a "new" PA out of some gear we carried together.
I'm not 100% sure about the crossover frequencies / settings and the setup (2 Way, Bi-Amped, Left, Right...???)
Signal Chain:
Mixer
dbx DriveRack PA+ (Left and Right IN)
Left LOW Out (Mono) --> QSC MX2000a (Bridged) --> 2x Turbosound TSE-118 (parallel)
Right HI Out --> EV DMC-1122a Controller Right Side
--> LF Out to QSC MX1500 --> EV Deltamax DML-1122 (MI)
--> HF Out to QSX USA 850 --> EV Deltamax DML-1122 (HI)
Left HI Out --> EV DMC-1122a Controller Left Side
Crossover Settings (as far as i could attempt with my knowledge??!)
HPF (Sub) BW18 @ 45Hz
LPF (Sub) LR24 @ 120Hz
HPF (Top) LR24 @ 120HZ
LPF (Top) ---
Dont' konw if it works that way, we need to run the PA on saturday so i'm a little bit concerned about the result.
Thanks in advance
StrungOut85
Signal Chain:
Mixer
LPF (Top) ---
Thanks in advance
StrungOut85
EV DML-1122
70Hz - 20kHz
HF 75 watts @ 8 Ohm
LF 300 watts @ 8 Ohm
TSE-118
40Hz-300Hz
300 watts @ 8 Ohm
QSC USA 850 (for EV DML-1122 HF)
2x 270 watts @ 8 Ohm
QSC MX 1500(for EV DML-1122 LF)
2x 330 watts @ 8 Ohm
QSC MX 200a (for TSE-118)
1x 2000 watts @ 4 Ohm (Bridged)
shall I overlap the LPF of the subs and the HPF of the tops???
isn't there otherwise a very strict cut between subs and tops?
for the system setup I have to choose custom speakers and custom amps
custom speakers bi-amped for the tops or not??
Yes. Custom bi-amp and custom sub (mono). The QSC amps may be in the Wizard (not sure), but custom is fine as well, since you are going to do a manual Gain structure. Right?
OOPS! - You have the controller for the EV's to handle the hi-mid stuff & PEQ adjustments. No. Select custom Passive with custom mono sub.
Custom speakers passive tops
Custom speakers mono subs
LPF (Sub) LR24 @ 100Hz
HPF (Top) LR24 @ 100HZ
LPF (Top) ---
gain structure manual
thx a lot!!!!! you saved my Saturday ;-)
cheers
strungout
