Need suggestions for QSC KW153/181 and DRPX
I'm new to this forum and appreciate the useful info here! Powered speakers and speaker management boxes are new to me but I've been doing sound off and on since 1968. We purchased 2 QSC KW181's and 2 QSC KW153's to use for local bands in small to medium venues in our area. That could mean an acoustic duet up to a 5 piece rock band that we would use this system for. Besides the QSC's, we have a new DRPX, 20 channel Mackie board, DBX 231 EQ, DBX stereo compressor, 4 two way 15" Seizmic Audio monitors with power amp rated at 800 w/ch 8 ohms/1200 w/ch 4 ohms/1600 w/ch 2 ohms. I've always relied on my ears and analog tricks in the past. I would also like to use the DRPX to EQ and catch feedback from the monitors, if possible. I am very interested in learning how to set up the DRPX to maximize the potential of the QSC speakers concerning hookups, EQ, compression and clean power output. The Mackie has stereo outs as well as a sub out also. I can see that there are several different ways I could hook this up and I've read the posts on using the calibration mic and general setup of the DRPX.
Any suggestions, guides, info or brain cell boosters will be appreciated!
Thanks, Polabear
Thanks, Polabear
viewtopic.php?f=61&t=959
Or maybe seen these posts?
viewforum.php?f=60
I will work my way through all of these posts and come back if I can't find what I need. Thanks for your reply and patience! Sorry for asking such a general question...
The PX really has no functional ability to manage mains and monitors. MAYBE if they were a common make and model of speaker could you have some success. Whichever (house or monitors) gives you the most problem or needs the most improvement is the one that needs the PX.
I have not heard the SA monitors yet. They are 15's with horns and handle 400w rms each. we will purchase 4 of them. Here are some specs:
Model #: FL-15MP (Pair)
400 Watts RMS, 800 Watts Peak
Woofers have an 80 oz magnet and 3" voice coils
1.5" Titanium tweeter driver with 10 oz magnet and 1 3/8" throat
4"x10" Horn
Two 1/4" inputs and two Speakon inputs
Frequency Response: 60 Hz to 20k Hz
Crossover: 12/18 db per octave 3K Hz high power with dual glass bulb tweeter protection
Impedance: 8 ohms
Sensitivity: 98 db
7 Ply Birch Plywood
Any suggestions besides using the high output on the PA+ would be appreciated! We're buying 4 of these and this power amp:
Product Code: MAGNITUDE2400
Model Number: Magnitude 2400
2 Channel Amplifier
Power Handling:
2 x 800 Watts RMS @ 8 Ohms
2 x 1260 Watts RMS @ 4 Ohms
2 x 1600 Watts RMS @ 2 Ohms
1 x 2500 Watts RMS @ 8 Ohm Bridge
Technical Specs
Frequency Response: 5Hz - 50K Hz +/- 0.5dB
THD+N: <0.05% @ 8 Ohms 1/3 PO
Signal Noise Ratio: >102dB
Slew Ratio: 45V/u S
Damping Factor: >400
Crosstalk: >65dB@ 8 Ohm 1K Hz
Input Impedance: 20K Ohms (Balance) / 10K Ohms (Unbalance)
Input Sensitivity: 0.8V/1.6V
Protect:
Overheat short circuits
DC limit and soft start
Smart Clip limiter Output relay control
Operation Power Voltage: AC 110V, 50-60 Hz
Front of Amplifier:
Channel A and B volume controls
Power indicator
Clip indicator
Protection Mode indicator
Signal indicator
Power Switch
Rear of Amplifier
Channel A and B signal input (XLR connector)
Operation Mode Switch:
Stereo
Parallel
Bridge
Channel A and B power output (Speakon and binding posts)
Ground/Lift Switch
AC Power Cord
Fuse
AC input: 110V, 50-60 Hz
Dual cooling Fan
Dimensions: 2 Spaces / Fits standard 19" rack cases
Weight: 36 lbs
We decided to go with this monitor setup, not because it was the best but because we are running out of money and need a monitor system to complete our rig and these are inexpensive. Hopefully they will be good enough! Total price for this system is $1149.97 Thank you guys for all your help!
RTA (b'ger) mic $50.
Yes I am familiar with those speakers and have worked with them.
Thanks for the X-over info also! You guys rock!
Polabear
They were wrong. The mic is a measurement mic, and there is nothing "special" about it. Most of the measurement mics out there use the exact same mic capsule, it's just packaged differently.
