Sorry if this already posted, couldn't find this combination
First of all I'm using this system in a live 4 pc band configuration (1gtr, bass, drummer, ld vocalist). I have 2 EV SXA250's pole mounted on 2 EV Sba760's. I am using the new Mackie Ipad mixer DL1608. I have 2 more powered hot spots and 2 more sxa250's for floor monitors. Would I just be better off using the crossovers in the sba760's as they're intended or....would I be better off using an aux out of the Mackie and splitting off to the two subs in mono and just using filters to create the sub out (as there is no sub out on this cool little mixer), or......would I be better off with a DRPA of some kind ie. plus, 260, 4800. I really need feedback control probably more than anything, would just a suppressor be enough? Thanks for all your help in advance.
Neil
Neil
Thanks again Gadget
N
Gadget, I must say you've been quite helpful.
Thanks again,
Neil
It's a good idea to set the same filter types on adjacent crossover points, so set the same..I.E..LR24 from the sub to the tops. If your dealing with powered subs there is usually no need to set an HPF for the sub, but the 260 has a brick wall limiter that can add additional safety. With 15" tops with plenty of power I generally go 75 hz for the HPF/LPF. On 15's with questionable power I would go 90hz even up to 120 if the power is low for the tops.
12" I usually go 118-135hz, even higher with less power..
So go into the wizard and set up your own, answer the prompts as closely as you can with your setup.
