Proper set up for JBL AM5212, PRX418S and DBX PA+ ?
Hi Everyone;
I have a set up for my church that includes the DBX PA Pro+, 2 Crown XTI 2002 amps, The House speakers are 2 JBL AM5212/00 and 2 JBL PRX418S sub woofers, my questions are: Is it more preferable to do the crossover setting in the Crown Amps or the DBX Pro+ unit? For these speakers with this equipment, what do you suggest be the crossover setting be (85 or 100 HZ)? I am looking at adding another Crown XTI 2002, one for each sub and the other one to drive the 2 JBL AM 5212, my installer originally ran it by doing the crossover in the Crown amps and only using the DBX for the RTA set up and feedback reduction, but the kick drum sound is not as tight as I would like it and we had to really do some serious eq'ing to take out the sharpness of the sound and to get the Countyman mic to not feedback, should have I just run it through the DBX and used it for crossover, filter setting. limiting and everything from the start? With this equipment, can someone tell me what is the proper setup? Thank you. ......Mark
I'd be tempted to get an XTi4002 or 6002 for the subs then run the tops bi-amped with your existing 2002's. Between the DSP on the amps and the DRPA+ you can get pretty specific with the way you tune your system.
As far as the kick's sound... what is the current x-over configuration? Don't rule out the mic, mic placement, channel EQ, and delay issues from speaker location.
go to the xover section and set the gains to -0- and the HPF and LPF to out...
OR
In the setup wizard select fullrange, and NONE for subs (if there aren't any..) use the high outs and set the LPF to out...again -0- for gain unless you need some to the ams.. which I never do as long as the input controls on the amps are @ -0-...
