iOs custom panel.
Is there a venue file available for the sample iOS app for HiQ? I am trying to replicate its strcuture and function for a project and I am unable to figure out how to get the Source Selection (or in my case the channels within a mixer) to be selectable.
R
R
It appears that the type of Control used is called a Value Combo Box.
Unfortunately when creating a HiQnet Motion Control Panel for an iOS device, it is not possible to drag/assign the input channel selection from a MID MIXER channel.
This is not a problem if you are creating a Standard Custom Panel but a HiQnet Motion Control based Panel does not support the Input Channel selection on a Mixer Channel.
It is possible however to perform source selection by dragging a portion of the Output RTE (Router) onto a HiQnet Motion Control based Panel.
One of the easiest ways is to select the OUTPUT RTE for which ever output channel (i.e. Zone you would like to perform the source selection in) and drag the top portion of the OUTPUT RTE (router) onto a Custom Panel.
Best Regards,
Jason Mondragon
dbx Technical Customer Service
Harman Signal Processing
8760 S. Sandy Parkway
Sandy, UT 84070
Phone: +1 801 566 8800 ext. 4627
Fax: +1 801 568 7543
Email: support@dbxpro.com
Web: www.dbxpro.com
SC64. IPhone Portrait Panel.
Lets say I go to ID 3.33.0 which is the Router for channel 1 on Card E (E33)
Drag it onto the design area and I get a Vertical Slider. Should this not be a ComboList box or some other similar control for selection?
Or am I missing something entirely here and I can use another type of panel for an Iphone? If not then do you mind a more complete example?
Thank you,
Ross
