Set up JBL SRX718, SR 4725, & Powered 12"'s
Can these be setup with the DBX PA+? I am currently using 2 SRX718's with 2 SR 4725's. I run the Subs mono with an XTI4000 Bridged and the JBL SR4725's with an XTI4000 in stereo. I would like to add a set of EV ZXL 12" powered cabs to my system. What is the proper way of setting up all these speakers using my Driverack. I was thinking of running the JBL's through the Driverack all in mono to the left channel of my Allen Heath board, then run the active cabs in the right channel of the board. Is there a better way?
Option 1: If you want the "JBL system" (4725's and subs) to be system unto itself, then adding more top end (only) with the addition of the EV's...
Set up the Driverack as a custom 2 x 4. (stereo Low)
Left mixer > left DR in.
Left DR Hi out > SR4725
Left DR Lo out > SRX718
Right mixer > right DR in
Right DR Hi out > EV's
Option 2: If you want the subs to be increased as either pair is turned up...
Set up the Driverack as a custom 2 x 3. (mono Low)
Option 3: If you want the "JBL system" (4725's and subs) to be system unto itself, then adding more top end (only) with the addition of the EV's... (this option allows separate GEQ and PEQ to be applied to each set of tops, as well a separate limiting levels and different HPF freq.)
Set up the Driverack as a custom 2 x 6. (stereo Low)
Left DR Mid out > not used
Right DR Hi out > not used
Right DR Mid out > EV
Right DR Lo out > not used
Option 4: If you want the subs to be increased as either pair is turned up...
Set up the Driverack as a custom 2 x 5. (mono Low) (this option allows separate GEQ and PEQ to be applied to each set of tops, as well a separate limiting levels and different HPF freq.)
Left (mono) DR Lo out > SRX718
PS - Option #4 would be my choice in most situations.
Imbalance: What happens if you swap the speaker cables? Cables from Mixer to DR? DR to amps? The only thing that can affect the L vs the R is the GEQ, and then if set up as dual mono.
