Proper Recording levels when using DBX NX40 and 224
I want to record onto cassette and open reel using either my DBX NX40 or 224. If I record to near 0 DB using either unit I get distortion on playback. Should I be recording far less than 0 DB with DBX or is there something else going on. I am recording to a Pioneer CT-F1000 and Teac A-1230 using quality Maxell and TDK media.
  • DraDra Posts: 3,777
    I can't answer your question directly, but can you monitor the recording in real time? If so, that would help you set the levels. 0DB may be zero headroom.
  • GadgetGadget Posts: 4,915
    So, your trying to get noise reduction on to tape? Are you familiar with what the noise reduction does? What cassette deck do you have? -0-dBv should not be a problem... does this happen without the noise reduction in the loop?
  • To all who responded - Thanks. I have gone back and more carefully recorded material on both decks. The distortion did not appear this time but I kept the record level around -3db. I did notice that with the DBX inline, the resulting record level was reduced about 3db while recording. Playback level was about the same as the non-DBX record level. So I guess I just have to more careful when I am recording with the DBX units inline.
