DriveRack PX Questions
I have a mixed setup of subs, one JBL PRX 618 S XLF, one JBL 718S, and one JBL M-PRO 255, and two JBL 615M's for main tops. I just bought a DriveRack PX. Can I use all 3 Subs with the PX? I already did one gig without the M-Pro but would like to use it also at an outdoor gig coming up.
Also, the manual says to set the pink noise to performance levels, I have a db meter, should I go by the meter? And how loud should I shoot for and not be too loud?
However, you have 2) 18" front loaded cabs and you are trying to add a dual 15" sub that is not front loaded. It is either a manifold, horn, semi-horn, or possibly a band pass box. That is bad news in most cases. The PX has no delay feature, but in your case that would not help sense there are only 2 outputs. You could manually delay (through placement) the 18 cabs behind the M-pro. How far would be trial & error? And to add to the confusion, it will be frequency dependent. In other words, 70hz may benefit, but 65hz may be hurt.
Performance level is relative. Pink noise can melt a horn driver if using too much power. Just imagine conversation levels (how loud you have to talk to be heard while performing) and use that as a reference.
So it would be much simpler to leave the JBL M-PRO 255 out of the equation, rather than experimenting with a delay or speaker placement? Would it make my low end sound muddy or un-defined and not punchy? I could also run it from a seperate send with a seperate eq, than from the same send to my powered subs and have more control of it that way, just trying to get the most out of what I have.
The bands I run sound for usually range in loudness from 100 to 115 db, I was just trying to find a reference point with the pink noise, I know the bands stage volume also contributes to the overall volume, would 95db be too much/little?
I'm not familiar at all with "pinking" a room. Thanks for the help!
I will say this. Can it help? yes Can it hurt? YES
Ground, generally.
viewtopic.php?f=60&t=2986
viewtopic.php?f=60&t=2908
viewtopic.php?f=60&t=2346
