Setup for outdoor softball stadium
Hello, My facilities manager bought a Drive Rack PA+ and speakers for our softball stadium. There is a Rolls-RM67 mixer. 4 EV ZX1i outdoor speakers mounted on the face of the stadium pressbox. They are powered by one Crown CX 302v amp. The amp is bridged and set on 70 volts. I need to know how to get this thing started using the DriveRack
zinger
zinger
Literally, you could use any preset, then modify it.
But it is really easy to set up a custom preset.
Start the Set-up Wizard.
Select Stereo EQ (not dual mono). This way you can use either input with it's corresponding outputs and the EQ will be the same.
Select speaker as "Custom" & "Passive".
Select Sub as "None", or "Without sub", or something like that.
Select amp as "Custom"
The only outputs active will be the High outputs.
If you input to DRPA Left then use the High Left output, or transversely to the right side if you chose.
Once the wizard is complete, enter the x-over module and set the HPF to the -3db low limit point of the cab with a slope of BW18.
These steps are from the original DRPA, not the +, so there may be a few differences.
Simply select "Custom" & "Bi-amp" & no sub (uses High & Mid), or "Custom" & "Passive" & use sub (uses High & Low). Each output goes to one channel of the amp. Set each output's filters as noted above (except also raising the Mid's LPF to OUT). The levels are controlled by the Gain settings for each band.
I can advantages to the basic and also the zoned approach.
Good luck. Let us know how it goes, or if you have any more questions.
