Looking for replacements for a 242 Parametric EQ Project 1
ramonovski
Hello DBX forum, I need your help.
I have one of your discontinued products, a DBX 242 Project 1 Parametric Equalizer, and after years of not using it I found that 3 of the potentiometers were broken, maybe a fall, I can't tell.
Here is a picture of the 3 broken potentiometers:
http://i.imgur.com/4Sdwuzx.jpg
The potentiometers are the "Gain" in the "Master" section and "Cut/Boost" and "Shelf frequency" in the "High" section, I'm not sure which one is which, though.
So, I'm wondering if you know where I can order a new replacement for each of these potentiometers.
It will be great too if you can provide me a schematic to see where these potentiometers should be placed in the unit.
I hope you guys can help me.
Thanks in advance.
Thanks in advance.
I will contact the tech support then.
