Tunings for the PA+?
frank4dfrank4d Posts: 17
edited June 2013 in PA General Discussion
While using the wizard for the Driverack PA+ I was able to select the model speaker I was using and indicated "passive" mode. Is this setup actually using some kind of tuning or EQ for the selected speaker? In the Driverack 260, I am able to see the tunings. I'm new to the PA+ and not sure if it even exists in passive mode.
  • DraDra Posts: 3,777
    If there is a choice for passive, then the model (I assume) is a bi-ampable model. VERY few speakers have any "tunings" (as in PEQ adjustments) in passive mode. The only ones I know of are the JBL M-Pro series. All you have to do to check is... go into the PEQs and look. Most all the x-over setting are very generic and not always to be trusted.
