Kick drum compression
Can the PA+ be used to compress the kick drum in the subs?(without affecting the rest of the mix) Mix wizard 16-3, SRX 715 tops, PRX 618S 600XLF subs. If not, what are some types of compressor settings should I use?(Country Music genre) Thanks
Sherman
Sherman
The limiter's are output specific, but are used primarily for speaker protection as opposed to audio correction / control.
Try a thresh of -9dB ratio of somewhere between 2:1-4:1 and fast attack and fast release and whatever you need for makeup. Start here
I can dial in a Kick and snare that will make your hair stand on end... in seconds...with NO noise, or connection problems, or interconnection problems associated with a bunch of diverse outboard equipment...
It's a killer combo ... the Driverack and the Presonus SL mixers!
