PA+ with powered speakers
Hello, this is my first post to this forum. I play in a four-piece cover band which doesn't normally employ a sound man. We use a Carvin 20 channel mixer, 2 Carvin PM12A's as mains, and 2 Carvin LS1801A's as subs. None of the bandmembers are particularly adept at handling sound man duties and, of course, we are all behind the speakers during performance. We've been unhappy with the crossover that is built-into the powered subs and, while looking into the purchase of a dbx outboard crossover, I saw the PA+ as something that could be a worthwhile investment (noting that the PX for powered speakers didn't have a crossover built-in). We haven't (yet) purchased an RTA mic as frankly putting out pink noise at performance volume wouldn't go over very well with most of the club owners we work for.
My question is this: do the factory presets--#48 Custom 2X4 seems like the logical starting point--include crossover and compression settings? Or do I need to apply those manually? I can't stress enough that while we are all experienced musicians, all of us have at best a rudimentary knowledge of all things PA related and any help or suggestions would be most appreciated.
Pat
Pat
#2 - With out even looking up what those speaker are I will suggest the subs be set to...
45hz (or 50hz) BW18 - 100hz LR24
set the tops to ...
100hz LR24 - out
Select any preset (I like to start with #1) and set up a custom passive with sub (mono or stereo) which will be a 2 x 4 or 2 x 3.
Any suggestions as to a starting off point for compression settings?
Mixer (Presnous 16.4.2) master L/R out (XLR) > driverack PA+ L/R inputs...PA+ High out L/R > tops L/R (SRM 450's) DRPA+ low outs > Crown MA3600 > subs.
This way we can evaluate better what your doing...
The speakers are active, the crossover built into the subs is dis-engaged. I used a custom 2X4 setup on the PA+.
We are a four-piece RnR cover band: guitar, bass, drums, keys/guitar/mandolin, with four vocal mikes. We call ourselves <a href="http://xsessionmusic.com">X-Session</a> but considering our band-wide lack of PA skills I'm thinking of something along the lines of the "Sonic Numbskulls."
BTW, we played for years using a Mackie 8-channel powered mixer into a pair of 15" JBL cabs but decided to upgrade to something with more power and range.
"#1 - The PX does have a x-over (it is called a band filter). But you will be happier with the PA+.
set the tops to ...
100hz LR24 - out
DRA"
I dialed in those settings and saved them to the preset. Last night was our first gig with those settings and, like I said, we still had bass going thru the tops. I then changed the settings on the fly and was able to get the bass out of the mains but it took everything else, vocals included, out of there also.
To get thru the gig we took the subs out of the PA+ altogether and daisy chained them from an unused monitor out on the mixer, enabling us to manually control what instruments (mainly bass guitar and bass drum) went thru the subs.
Something is not meshing here.
Try loading in any listed mains and subs and see if it sounds like you would expect then check what the settings are.
Then highlight "H" in the upper left corner (shows your adjusting the high outputs) and you have that set to 100hz LR24 ... right?
