260 Setup Almost There!
Thanks to great info here I've gotten through the setup up of my Driverack. Gone through the gain setup and the crossover recommendations from Gadget and everything playing well together. Playing recorded music through the system I can here a noticable difference in clarity and punch.
I have a modest Yamaha MG206C board, Yamaha S115V tops fed by a QSC GX5 and SW188V bottoms fed by QSC GX7. I do still have DBX2231 betwen the board and the DR 260 for quick tweaking if necessary (very little needed).
Curious about one thing.
The output on the MG206 is near clipping when setting the gain structure, and the power amp gains have been adjusted as recommended to prevent clipping. The interesting (to me) thing is that the input and output meters of the DR 260 are not very high. Should I adjust the inputs levels of the DR 260 to get the signal higher, or is the fact that its digital and the SNL isn't as critical mean the lower levels are ok. Is the DBX 2231 the issue? Do I need to get more gain out of that to drive the DR 260 higher? By low, especially on the output side, I mean the high and low meters are two or 3 yellow lights at most.
Just don't know if I should leave well enough alone, or if more tweaking is needed.
How do I get it up there if its not there?
I thought I read if you alter the input gain, you throw off the calibration of the meters?
Phiilp
