Setup for JBL SR4722x Passive
Just MikeJust Mike Posts: 2
edited August 2013 in PA Configuration Wizard
I see there is a preset for the SR4722x 3 way, but I want to use the tops passive unless someone can convince me they'll sound remarkably better going 3 way.
So is the easiest way to do this is just modify the 3 way preset and run the mids all the way up? Or should I run the Highs all the way down? Or does it matter?
BTW, I'm running 2 4722x's over 2 4718x's on either side.
  • DraDra Posts: 3,777
    I assume that bi-amp settings include several PEQ and band gain adjustments. You should not use this preset for a passive set-up. You would have to undo so many things that starting from scratch would actually be easier.
    Bi-amp? Is it better? Very likely. Is the set-up more complex and expensive (extra amp and cabling)? Yes, unless you have spare gear around.
    If you really want to know, set up a one over one bi-amp and a one over one passive and compare.
