Want to double check my limiter settings..
Driver 2'" compression horn 250watts @ 8 ohms - 44.72v | 35.22 dBu
Amplifier 1100 @ 8ohms | 26.00 dBu
Limiter settings should be about | 09.22 dBu
Attack ? ms
Hold ? ms
Release ? dbs
Assume I want the driver to see about 400-500 watts but no more...
Attack ? ms
Hold ? ms
Release ? dbs
With no speakers attached, connect a multi-meter (set to AC volts) to the binding posts. Limiter off. Send a tone signal through the DR260 that is at your peak output desired.
Turn on the limiter, with a fast attack and a fast to pretty fast release. Duration of the hold can be all over the place. Then adjust the actual voltage, I like t reduce the input attenuation of the amp to achieve the desired voltage max. Next work on the reduction with the limiter.
I believe its 250 program with crossover over 1200hz
But ill try the multimeter trick makes sense.. What tone should I use or is pink noise sufficient..?
