L to Front of House, R to Foldback
Mono front of house mix.
I play in a band and am also setting up the pa for about 150 people. I'm thinking of using three prx612 powered speakers like this.
Main out from mixer through driverrack then left channel to both front of house speakers and right channel to foldback.
This would allow me to use a separate GEQ on each channel (each area) and get a decent loud sound in the centre of the stage with the AFS. I plan on moving the rta mic while setting the auto eq for each area.
My desk also has 2 aux sends which we could use on another 2 side wedges to boost anything the musos want more of eg electronic drumkit one side keyboards the other.
We also have someone mixing out front.
Does this sound great or foolish?
Using the main out meant that the main fader turned up the foldback with the front of house so would use a separate group on the desk next time (had a 1/2 and a 3/4 bus unused).
One of the prx612m died the second time it was used so the shop gave us a loaner (a behringer). I put the foldback speaker vertical on top of a beer keg in the middle of the dance floor pointing at the drummer but the band didn't like this (a small 1 ft stage) so we put it on it's side at 45 degrees. This was done after the auto eq unfortunately and detracted from the onstage sound. One thing I got wrong on the initial practise run was setting stereo linked. For the gig I used dual mono and moved the rta mic on and off the stage for the left and right auto eq. I blame this mistake on the number of people in my ear asking me "how does this thing work" while trying to read the tiny display with my poor eyesight.
One issue I had was with feedback and I realise now that it was probably because the AFS release was set to 5 mins. Next time I'll set it to 60mins.
When I know how to drive this it can only get better.
Personally I think this is less than ideal and for me a takes away the control and independence between the FOH and Monitors.
Are you just using your PA for vocals only or are you plumbing in some instruments through too, as I would only use what you described for a vocal only set up.
When I purchased my PX rack I ended up re-using my redundant FOH graphics for my monitors. I have two aux send from my desk and I use the left Channel of the EQ going to the floor monitors at the front of the stage and the right channel goes to me for the drum fill. All of my speakers are Powered so this is an ideal set up for my situation and that allows a separate feed into the drum fill that is different to the other musicians which is different to the FOH.
I takes a little getting used to but since I got the PX and nutted it out with some confirmation from this forum, it is taking 45 minutes off of our set up times and at most shows we do a full mix. Three vocals, drum kit, Guitar and bass.
Also since we go t he PX other bands in our town are asking me to do there sound on my bands nights off as they are so impressed with the sound the PX is producing. See picture attached - sorry it's not that clear.
