graphic equalizer with driverack pa+
Does the driverack pa+ have a built in eq that you can use for the overall mix? If not, you would recommend using one and where abouts in the signal chain to use it. At the moment I have an old Peavey eq on the master inserts, my other eq option is I have a Beheringer ultracurve pro, I know Beheringer is lower end gear but the reviews on it seem ok.
cheers for help
simon
cheers for help
simon
Cheers again
Simon
