DR 260 delay granularity
xyrium
Hey Folks,
I am using a DR 260 to manage a pair of studio monitors and pair of subs. All 4 have built in amps. THis said, I'd like to add delay to the mains in order to allow the rear subs to catch up. I was thinking somewhere in the range of 6-10ms, but that does not appear possible on the DR260. Is 20ms the smallest increment available in the post-xover delays? It seems to be the smallest amount available in the GUI, or in config mode o the panel.
Thanks!
Thanks!
Right click on the output(s) you want to add delay to.
Select 20ms (if you need less than 20ms, if more select a higher range like 50ms).
Click the config button and confirm the change.
Double left click the "D" on the output to open the delay module for that output, or linked outputs.
Select the time (ms), feet, or meters units you wish to work with.
Use the slide bar to set, or click on the actual units' setting (it will turn yellow), then type in the exact setting you want and hit "Enter".
Thanks for the help on this one, though it should have been straightforward to me in the first place. :oops:
