question about driverack pa with EV ZLX12P
rodflashrodflash Posts: 17
edited November 2013 in PA General Discussion
i have a driverack pa "not the plus",i want to run my small power setup,
which consist of,1.behringer eurolive B1500 pro and 2.EV ZLX 12P,
what should my settings be
thanks in advanced
  • DraDra Posts: 3,777
    Looks like there is some DSP activity going on. At least with EQ, but "limiting" is of an unknown type. Set a fail-safe Hi-pass filter at 45hz BW18. You could set the limiter in the DRPA to a point just outside the limiter on the EV. Maybe 3db, Over-easy off. Again, as a fail-safe.
  • i'll try that and see what happen,or should i run them without the driverack
    GEQ
    AFS
    PEQ
    are reasons to use the DRPA with any speaker.
    Sorry, I did not realize that the B'ger was a sub. I thought is was a mixer. That changes every thing.
    sub - 40hz BW18 - 100hz LR24
    tops - 100hz LR24
    In the Wizard select stereo linked, custom passive, with mono sub.
