crossover query drive rack pa+
funkyblufftonefunkyblufftone Posts: 12
edited November 2013 in PA Configuration Wizard
Could someone explain to me the difference between the two pictures please as I have followed the instructions and put in my crossover frequency for my bass bins which are Adlib Audio AA15HL (crossover frequency 90-100hz @24db/oct) I am unsure of the meaning of the 24db/oct . As in picture one I have entered my crossover frequency but when I press nextpg I am presented with the second picture and am unsure how to proceed and what this setting should be? Also I have had to raise the output gain in the low frequency to 10 because the volume was extremely low, is it ok to do this?
Many thanks
  • DraDra Posts: 3,777
    One is the HPF (HIGH PASS FILTER). This sometimes is called a low cut.
    The other is the LPF (LOW PASS FILTER). This is sometimes called a high cut.
    These two together set a band pass filter.
