Any info on the NEW Driverack PA2-hands on?
I like the layout of the new PA2. Appears like they eliminated the layers in the menu navigation. The website claims faster, easier and better. Anyone actually have one yet?
Jim
Jim
The PA2 has not been released yet, but I can tell you it is a pretty slick machine. Navigating the front panel is slightly different from the PA+ and PA, but it's a great design. Also controlling the PA2 with Mac, Windows, iOS, or Android will make it a better experience also. The Auto-EQ and AFS features have been revamped, and will be much more efficient compared to the PA+.
Josh
dbx TCS
Here is the link.
http://tinyurl.com/driverack
(for a bit of background, the system I'm running is a Crown XTI-4000 and 4x JBL SRX-715s for the tops, and two Crown XTI-6000's powering 8 JBL SRX-718Ss for the subs. Signal is sent from Pioneer CDJ-2000 Nexus players, plugged into a Pioneer DJM900 Nexus mixer).
Having used a PA+ up until yesterday, my first impressions are the following:
- AutoEQ allows three levels "Good", "Better" and "Best". So far, I've only run through the Wizard with "Good". It required three different positions of the RTA Mic. To my ears, my system seems to be much "sharper", the mids seem to have better articulation, the content seems more faithfully reproduced.
- Setup via the new menus is faster, and easier.
- I downloaded the Windows app and took a look at the various settings from my PC. The application is dead simple to use. The user interface is extremely easy. You can actually "see" what autoEQ has done, graphically.
- Aesthetically, the new, black faceplate is more attractive than the PA+ silver color.
- Would be great if a firmware setting under utility allowed for the red "Wizard" illumination to be switched OFF. It's quite bright!
- The new level LEDs (horizontal lines, rather than small squares) is more visually appealing and more easily observed, especially when you're at an extreme angle (nearly beside, but parallel to the faceplate).
- I didn't see the iOS app in Apple's app store yet, did I somehow manage to miss it?
- The higher resolution display is a plus
If you guys have any other questions, I'd be happy to answer them if I can.
-Matt
I see you own pretty much all the DBX PA units, how is the sound quality from the PA2 compared to the 260?
