System configuring with 2 driveracks
Hey!
Im little confused, what is the best way to connect these...
Driverack PX , Driverack PA
Subs: Mackie HD1801*2, Db Technologies Arena SW18*2 + t.amp 2400 & The box pro TP218/1600 MkIII + t.amp 2400(bridged)
Highs: Mackie SR1530Z
http://www.mackie.com/products/hd1801/
http://www.dbtechnologies.com/EN/Produc ... _p755.aspx
http://www.thomann.de/fi/t-amp_ta2400.htm
http://www.thomann.de/fi/the_box_pro_tp ... _mkiii.htm
http://www.mackie.com/products/sr1530z/
Why? I'm sure you can come up with a senario that will not work with dual DRs but in general, I don't see a problem.
Dennis
4-way stereo (no LPF on the high outputs)
3-way stereo w/ stereo 2-way zone
Inserted input channel processor
Side chain processor
More impressive rack
Im not really sure what some of these configurations are (my bad, not yours) but explain "3-way stereo w/ stereo 2-way zone".....if I am understanding correctly, I don't see a problem using two DRs
A user of a PX (as marketed) typically would not have a need to operate a PX and a PA from the same console / mixer at the same time.
What physically would stop you from doing it? A timing issue? Would your opinion be stated differently if we were talking about two DRPAs? Or two DR260s?
I'm aware the OP's equipment list is a mismatched mess but two DRs are the least
of the issues.
I've noticed you have been pretty much solo lately on this forum??
Yea, kind of lonely round here.
Ive considered doing this and might at some point, unless I can figure out a different way of doing it.
I don't think the time alignment has a long enough delay time to use one of them for a delay tower, or however you might have some kind of speaker system behind the sound board.
