Help using EV Tour X speakers
Hi,
I love the PA+ but the EV Tour X 1152 speakers are not listed in the speaker tunings. I've run it by using Custom but was told the JBL SRX speaker spec's are almost the same. Can I run it like that or is there another way to setup my speakers?
Billy
Billy
The high pass on these speaker are 40hz. Should I set it that low? The Subs freq resp is 35-3000. Would that cause phase canceling?
Specs are:
Freq resp 55hz-20khz
Freq range. 40hz-20khz
Rec. hi pass freq 40hz
Axial sensitivity 100db
Max spl 133db
Power handling 500w to 2000w peak
Crossover freq 1650 db
Should I just set the speakers under custom? Tour X's to 65hz bw18 and the subs 35hz to like 80 in the crossover settings and call it a day?
I find it hard to believe that any sub has a range to 3000hz.
However, for the sub... high pass at what ever the -3db rating is using BW18. Cross the sub to top at 90-100hz LR24.
