help with my crossover
i need help setting up my PA for live shows. I have a mackie 1604 aTC electronics m350 reverb, 2jblprx 515 self powered tops and a jbl jrx118sp self powered sub. we used this for a small bar show last month (1st time using the sub and the crossover) it worked well although I'm confused about a few things . !stly i was told by a few people that the tops should be connected to the high output on the cover and the single sub to the low using the sum function. after a lot of messing around with it sounding crappy i put the tops into the mid output and the sound was great. is this because of the 515s having built in crossover. i also am unsure where to set the other xover knobs or if they are even engaged. as you can tell i am no engineer but since i own the stuff i guess i am elected. we have 2 guitars, bass, drums, percussion 3 horns and we mic the bass, kick ,guitars percussion and 4 vocals.....whew!!! thanks for any help
