Driverack PA2 Mackie sub SRS1500 vs SRA1501 & JBL 712PRX
Getting my PA2 tomorrow!
Pumped!!
I looked through the subwoofer list & I noticed theres the Mackie SRA1501 but not the Mackie SRS1500 which we have 2 of.
When you compare the very old now SRS1500 vs the SRA1501 the differences are relatively minimal... almost the same freq response graph, SPLs, woofer, box etc.... so
Can I use the Mackie SRA1501 setting for my SRS1500 subs?
1500 manual
http://www.mackie.com/pdf/archive/srs1500_om.pdf
1501 manual
http://www.mackie.com/pdf/swa1501_om.pdf
My mains are the new JBL PRX712... I didn't see those on the list, only the PRX612s. I imagine these will be added by firmware later... Should I use the PRX612 or Not listed for these?
1500 manual
1501 manual
When I chose my speakers JBL PRX612 & Mackie 1501 it gives me a dial for gain up only 23% for the mains & around 32% for the subs. Not sure why that is but nothing was connected to it at the time. Full set up tonight for an informal motorcycle gathering where I can tweak all night.
One of my SRS1500 subs is on the fritz so I'm looking at the 718XLF or the new SRX818SP, just one
We run our mains stereo for the keyboards... so with one sub I have to still use the PA2 regardless
The 718xlf automatically crosses at 90hz. I'd imagine I'd tease my 712PRX tops down to 100hz LR 24 if the kick drum doesn't blast the hell outta them.
The SRX has a much better range on the limited specs they give with performance up to 120hz so I imagine I'd cross there with those which would take some kick out of the mains (A problem we had in the past). I have to guess that the cross will be variable with the controllable DSP of the SRX line.
I'm leaning SRX personally. We play medium sized clubs. The 2 SRS1500s were enough & I'd imagine one SRX is at least equal to those 2. Should be able to get away with one of those. I really wish the PRX had some improved performance past 90hz
BTW. Did the new PA2 updates recently add the 700 PRX line?
DRa
Theres the spec sheet that says 100hz & the Manual that says 90 hz with a 48 db slope
http://www.jblpro.com/ProductAttachment ... XLF_v5.pdf
http://www.jblpro.com/www/products/port ... OtP7nzF-rZ
Anybody with a JBL in know which one is right?
Yeah, if you click on the users guide for the 700 series 90hz with a 48db slope is in the specs. That could have been an oversight moving from the 600 series
The JBLs running at 100hz with the 48hz slope makes me want to move the crossover with the PA2 down to 110hz 24LR on the 712PRXs. I feel comfortable running my setup like that if the SRX subs aren't a go.
I've ruled out a bunch of other subs. My rep at RMCaudioDirect is getting his info on that sub today, fingers crossed!
So I'm waiting for it!
Next gig I'll be rearranging our rack & getting the PA2 to control our mains & subs again vs just doing the kickdrum sub thing
I'm going to bring it home to update it & see what the new firmware changes. My main peeve was locking the crossover & I think thats been removed. Since I'll still be using the SRS 1500 with the 712 PRX tops I'm planning on a 120 crossover with LR 24 on both... a 40 hz high pass on the sub. I'll probably notch the 120hz 31 band EQ down about 3 db just to make sure they dont sum at the cross point.
Thanks for the tips! I'll report back with the results after the gig Saturday
Surprised there wasn't ANY updates or changes to the tuning list. Still now PRX700 series? What the heck?
In anticipation of the new 718XLF I'm setting up my PA2 now. My MAIN goal for Saturday before the new sub comes in is to NOT have the kick drum beat too hard in the 712s
So
110hz crossover BW48 at the tops. To capture a little bit of what the XLF cant do but to get more lows out of the mains than a 24. Went with BW as I'm not worried about any summing since the XLF is rolled off good at 110db anyway.
I'll let the subs do their natural 100hz cross 48db
I have a BW48 slope starting at 35hz for a high pass on the low... or should I just do a shelf, or does it not matter?
I also have a setting for just the PA tops when we play without subs... I'm thinking of running a hard shelf at 50 hz
I have PRX635 and 618S-XLF with the driverack 260.
If my memories is correct and when I had PA+ the settings was for the x-overs settings:
Low: OUT
High: Highpass; BW 18, 118Hz
X-overs bandpass gain both Low and High: 0dB
There is no reason to use x-over settings for the subs because there is internal DSP in the PRX system.
Do like this....
If you use the PA2. Connect the Lows OUT to PRX718 and there is a button on the back panel on the 718XLF for the x-over, set this to "OUT". The DSP in this sub will handle the x-over settings and this is 90Hz 48dB slope according to the manual. Here you can use High pass filter from 100-120Hz BW or LR from 18-48 slopes to the main speakers. Try it out and see what sounds best. Set the x-overs band pass gain to 0dB.
If you don't use any Driverack, then in passthru connection, the button schould be "IN" and the settings will be Highpass 120Hz, 24dB/octave slope according to the manual on page 19 of the PRX700 system.
If you do like this then you don't have to fiddle with the x-overs bandpass gain and having signal loss thru the driverack.
You're right, I ended up selling my PA2 as I'm just gonna use the Xovers of JBLs & the EQ stuff will come from a new digital mixer. Had to raise some funds. In the "old analog world, the PA2 is perfect but with the new digital things you can go rackless, clutch!
