Pa2. Limiter. 0dbu or -20dbfu?
ivan23ivan23 Posts: 6
edited June 2014 in PA General Discussion
I can't understand how I must set the Limiter if I want set threshold on 0 Dbu. When I set threshold 0 Db on Limiter it means 0 Dbu or 0 DbFU(+20 Dbu)? Help me, please!
  • DraDra Posts: 3,777
    Are you limiting power from the amp to the speaker for a particular max voltage, or are you just setting to keep the amp from clipping?
  • ivan23ivan23 Posts: 6
    viewtopic.php?f=61&t=959
    This is the Start Here Thread. It will explain what you need to do.
