Bose L1 Model 11 System & the dbx DriveRack +
I have a Bose L1 Model 11 System trying to use the dbx DriveRack PA +. I am trying to use the preset #50 and sweeping the venue using the AutoEQ and things are not working well. I was hoping someone else has had some luck with this setup and and would be able to help
some dummy get his act together. I am missing something in the configuration and it might be setting the pink noise level. When I turn the data wheel until pink noise is playing at a level (-5 db to +5 db ) or any other level it will just set after hitting next page and will not ever complete. It says this may take several minutes and I have left it there for close to an hour with no results.
Frank
Frank
How does it sound run flat? Tweaked by ear?
