Home dbx User Forum dbx Archive Threads dbx Archive General Connectivity
Zone Pro 1260 & ZC2 Connectivity issues.
PhillayPhillay Posts: 3
edited August 2014 in Connectivity
Hi all,
I am having issues with my zone pro1260 and ZC2 staying connected.
Basically when I have the laptop plugged into the zone pro via ethernet, the ZC2 functions and performs
as you would expect.
I store the settings to the zone pro and then as soon as the laptop is disconnected from the ethernet port, the ZC2 stops functioning.
Any ideas?
Thanks in advance.
  • DraDra Posts: 3,777
    You may have tried this, but sometimes after being control by the laptop you have to cycle the ZC (turn the knob).
    Is this a new problem, or a new install? Make sure the mute is not activated.
    If that doesn't do it, call tech support. They are very helpful.
  • PhillayPhillay Posts: 3
    Finally sorted it out.
    I had programmed the zone pro and then later added the zc.
    The zone pro didn't want to save the new info with the new zc added.
    I started from scratch with the programming now with the zc included and it's working fine.
