Confused about mono/stereo and pink noise behavior
I have a PA with two powered subs and two powered 2-way speakers on top with a PA+. I want to plug all speakers individually into the back of the PA+ due to how I prefer to physically run my cables. In Wizard I selected mono input and stereo subs and stereo tops. Of course I run into the hated right/left balance issue in Wizard, but once I faked that out, I went on to Auto EQ and the pink noise only came out of one side of the system. How do you run a mono system and still use the left and right outputs on the PA+? Can I just set it up for a complete mono system, and still just use the left and right outputs on the PA+? (I don't have the PA here to try).
1) Outside (away from all reflective boundaries (except the ground) - One side of stage stack (if you center stack you subs, use half of them with your stack). Mic 25' in front, on a stand pointing (leveled) at the low driver of the full range cabinet.
This is for system flattening and balance.
2) The point the mic tip at, and very close to, the floor / ceiling / wall... it to reduce the far reflections from affecting the results. (The very close reflection will be very much louder than the far ones, so it will dominate.)
3) The lay the mic on carpet (or better... a very thick / folded towel on the floor or table) method reduces the effect of the close reflection. Stand not needed.
2 & 3 are basically the same, but are used for pinking the room you are in to minimize resonances and nulls. Your choice as to which you utilize.
Hope that helped.
At 7', depending on vertical dispersion...
40 deg - at least 12' from the speaker,
50 deg - at least 15' from the speaker,
60 deg - at least 19' from the speaker.
Whatever the distance, it is best to have the wall facing the speakers (rear of the room) at least 2, 3 (or more) times that distance from the mic. Side walls also, if possible. That make the direct sound much greater than reflections.
