Driverack 2 & JBL PRX725/PRX718XLF
3beee3beee Posts: 2
edited September 2014 in PA General Discussion
Hello,
I'm new to the audio scene and need to know how to set up this unit with JBL PRX725/PRX718XLF. The guide said plug the full range into the highs. I assume you would connect the PRX718XLF to the low. Then go with the “Not Listed� option?
Roger
  • DraDra Posts: 3,777
    Yes.
  • MctwinsMctwins Posts: 113
    Hallo!
    I have JBL PRX635 and 618S-XLF and when I had PA+ connected I run the settings which where on the list in PA+
    High Pass 118Hz BW 18dB/oct
    Low Pass Out
    X-over gain "0" on both Low and High
    Works fine with these settings.
    You schould be having the settings for your 700 series in your PA2, if Driverack 2 means PA2?
    I have now dbx260 and there is no settings for the 600 series or 700 series. I am currently running in 260 with the settings;
    High Pass 93,6Hz LR 48dB/oct
    Low Pass Out
    X-over gain "0"
    Works fine here as well.
