Wireless control of DR260
How do you make use of bluetooth or serial to ethernet adapters to set up a network and control wirelessly a DR260? I already have a serial to usb cable which works fine, but I use a digital snake and would like control @ FOH, instead of on stage by the amp rack. I already have/use a wireless router for the console.
If you're using a serial to ethernet adapter, try this:
"DR260 serial connector" to "adapter serial connector". (Null Modem Cable)
"Adapter ethernet connector" to "wireless router ethernet port" (NOT internet WAN port)
Connect to router wirelessly with computer.
