Moving to powered speakers...Driverack PA+
Been here before, and read thru "Start Here" again as a refresher, along with some similar posts.
Powered speakers are now used in my system (EV ETX35P)
Still running passive subs, JBL JRX118 (x2) powered with Peavey ipr2 5000.
First show I ran PA+ just like I used to, x-over, auto EQ, etc.
Everything was great, but should I be running highs full range, and subs crossed?
In a few days I will be adding some EV LiveX 18" Powered Subs.
How should I setup then? Full range using DSP on speakers, or crossed thru PA+
I really like the AFS, and have good results with Auto EQ RTA on towel, placed on floor, or table, in front of one stack.
Questioning the future use of PA+
This would save on some cable run....I have read a few other posts on this, but they were crossed at DRPA.
The ETX speakers sound killer full range with recorded music, even without subs.
Just wondering if anyone else has tried different hookups.
Don't want to use anything I don't really need, or hold on to fairly expensive rack gear that is losing value daily.
It all depends on how much control and tuning capability you want at the DRPA vs minimal cable runs.
So, I am assuming that not that much will change with DRPA+.
I will setup as stereo full range, high L/R will be the only out from DR...skip balance, run auto eq, afs, no compressor, limiter yes, but I need to gain structure again for limiter, and the powered speakers?
Can I be using some kind of creative setup using other outs...mid/low on monitors? Just wondering about that, monitors are pretty good now, but it would be nice to have processing, the afs works great for us on the mains.
Right now I am not using any eq, or notch filters from the digital board.
Also crossover point on speaker dsp...35P are high end 3-way. Subs are entry level.
Thanks for your help!!!
I have noticed that some are being advised to crossover with the DRPA, and others with the speakers dsp.
I will try both, but would there be a reason to do one or the other? Is there more control with the DRPA?
IE: the BW/LR choices...Do some speaker brands have a better DSP that would make you(Dra) want to use that.
I sounds like a stupid question, but I am curious of your opinion Dra, or Gadget.
I chose 100, as that worked well before. I was not able to tell any improvement, and maybe the tops sounded a bit harsher in the high end.
Next show I will x-over with DR. That sounded better with my passive subs, and I do like the level control that the DR has.
Still need to outdoor / baseline eq, it is hard to find time to unload everything off trailer between shows working a full time job.
Am I right about full range stereo being 2x2? What do the numbers represent. It works better if I start with a preset that has what I'm using. Also there is no Active Custom in setup, so I choose Custom Speakers, Custom Amps.
Feedback is not a problem, and I usually have to just about max out channel, and main outputs to get something to catch.
It is very loud at that point.
2x3 = 2 in, stereo highs and mono lows
2x4 = 2 in, stereo highs, stereo lows out
etc
