Need config help with DRPA
mrshaynemrshayne Posts: 2
edited November 2014 in PA Configuration Wizard
I bought-out a pa system and the drpa was part of the package. Didn't get any instruction whatsoever. Here's what I have: 2 Yamaha club series 115v's and 2 Ev 18" subs - all passive. Running the system mono with one QSC 2450 amp (I also have a QSC 1450 that I'm not using). Out of the DRPA: Lows to one channel and mid/high to the other. However, all the diagrams I see are using 3 amps, one each for lows, mids and highs. The Yamahas have a 15 and a horn. Do you feed it from the high or mids output? Or is there a better/recommended way to do this. I'm a guitar player and PA stuff is relatively new to me. I would appreciate some advice.
Thanks!
  • DraDra Posts: 3,777
    In the wizard set up a custom passive highs with custom subs. In this set-up, you'll use left or right side in and the same side out highs and lows.
    I would recommend, lows 40hz BW18 - 100hz LR24, and highs 100hz LR24.
