2x4 settings
I setup my 260 via wizard for 2x4 jbl srx 725 and 728s. I noticed there is a signal being sent to channels 5&6 as well. Shouldn't it only be 1&2 for highs and 3&4 for lows? Also, is there any known setting for pl380 amp for subs? Thanks
I mimic'ed your setup and 5 was assigned A and 6 was assigned B. Every output has to be assigned an input. Just mute the outputs.
You can find a similarly gained and powered amp that matches the PL.
Before. Also went with 32db v instead of the 26db I was using on pl380.
