AFS-224 suggestions
LightGuy48
I've got a pair of 224's that I use for my monitor mixes and I really love the units, they have worked very well but I was reading something recently in the manual that made me re-think some of my usage but I'm not sure how is the best way to use the feature.
In the manual it states you can switch the filters as you ring out the system. I'm just not sure how you can utilize this feature. For example, let say if you have 12 fixed filters would you want to ring out the first 3 at high music, the next three at med music, the next 3 at low music and the last 3 speech? Or maybe reverse that order? Or maybe do 6 and 6 at high and med music? Or just all of them at high music? Obviously you're changing the width/Q of the filter
One thing I've quit doing is using the live filters and just ring out beforehand. Most everything I do is live music in a club environment and I've found the live filters are too easily tricked into catching a ring from a guitar. If I have a ring issue during a show I just take care of it by hand.
As I mentioned I'm considering dropping my live filters and going with only fixed filters or maybe just a small number of live filters because with the bands I work with their guitars seem to trigger the AFS too easily. I've done numerous sets with zero feedback yet I'll see 4 - 5 live filters engaged.
Does your mixer have the ability to matrix the vocals as a group to each mix? That seams like wishful thinking, but would solve your guitar problem.
You mentioned using a matrix, so what were you thinking? Vocals into an aux and instruments into another aux then sum them into a matrix and using the AFS as an insert on the aux?
Yes, if it will.
