Drive rack 260 System Setup Locked
Halo, I have just bought a drive rack 260 and have been trying it out and somehow locked my self out from doing any new system setup. I remembered it was a low security, but I did not enter any password. How do I unlock it? I have tried soft reset and pressing the RTA button while powering it up, but still locked. Can anyone help please. Do I have to do a hard reset? Thank you
System Lock Out
• Press and hold <RTA> at power-up until one of the following messages appears:
System Unlocked All user input will be accepted
or
System Locked No user input will be accepted
• Rotating the <DATA> wheel to select either Lock, Unlock or Filter Unlocked the system.
• Pressing <PREV PAGE> will unlock the system if it were locked or it will lock the system if it were unlocked.
• If you wish to leave the system locked with the exception of being able to clear the feedback filters, follow the same
procedure on power up and then rotate the <DATA> wheel to select the feedback filter unlock feature.
• Pressing any other button will abort the System Lockout sequence and the unit will reset normally.
Cheers
