Difference between DR260 and Venu360
Hallo!
This new Venu360, has it the same feature regarding the brick limiter as found in driverack 260? What is the difference between these two units?
I have the 260
I have the 260
I downloaded the Control App for Windows and play with it a little bit and it looks pretty cool.
Seems to me that it has the same limiters as in 260.
One other thing. The control app device must be "connected" to the 360 in order to access the wizards. In other words, you can't select speakers and amps to do an off line set-up. I have communicated with tech support and they are working on allowing that part of the Wizard to be functional.
