Home dbx User Forum dbx Archive Threads DriveRack PA2
PA2 setup: two JBL PRX 735s & four JBL PRX 718XLFs
DeeMfDeeMf Posts: 3
edited August 2015 in DriveRack PA2
Does the PA2 have presets for the JBL PRX 735s & JBL 718XLFs?
Or will their specs need to be manually entered?
Do i need to update the firmware out of the box?
Thank you in advance,
Dee...
  • DraDra Posts: 3,777
    The PDF on the website is not dated, so it's age is not know, but the speakers you have are on there. However I would think that the nearest previous model should be close enough to set the HP & LP filters and the gains. But, it there is an updates firmware, yours may be included. You can try tech support.
  • DeeMfDeeMf Posts: 3
    The PRX 7-series is on the pdf? i didn't see it.
    But updating the firmware might provide an option for those speakers?
    How do i contact tech support?
    Also, should i set up as a two-way system (using only high & low outputs) or three-way (using high & mid outputs to the 735, and low to the 718)?
    Sorry. Left off the "NOT" on there.
    Updating MAY include them, but only if it is (ha).
    Click on the Tech support link above and call them.
    You have powered speakers. You cannot do anything but send one signal to them. Highs to 735 lows to sums.
