DRPA on Monitors
Blueyes1971
Hi all,
I have been using my DRPA on foh for some time now and have recently acquired another to run two monitor feeds.
My system consists of
Mackie 24 desk
2x DRPA
Crown Macrotech 3600 running peavey dth4 tops
macrotech 5000 ( when using peavey dth-218 subs)
I have two wharfdale SVP-12pm monitors 300w and 2 X passive
I'd like to run my second DRPA on monitors this coming weekend and any advice setting up in the wizard , gain structure, hpf and lpf roll offs, and limiting, would be greatly appreciated. As I'm struggling for time with my gear this week due to work commitments.
Many thanks
Mackie 24 desk
2x DRPA
Many thanks
Nut shell:
Stereo
Dual mono EQ
Speakers - custom passive w/ stereo subs OR Custom bi-amp w/out subs (I know the 1st option will use the hi & lo outputs. The 2nd... may also, might use hi & mid outputs, but I think hi & lo.
Amps - custom
Mon 1 - Left input > Hi (left) output.
Mon 2 - Right input > Lo (right) output.
Mon 1 modules available - GEQ (L), Limit (hi), PEQ (hi), X-over / filter
Mon 2 modules available - GEQ (R), Limit (lo), PEQ (lo), X-over / filter
Mon1 & 2 will share the AFS (if one mix has feedback the AFS will alter both mixes, even if not needed in both). They will also share the compressor. If used, make-up gain is NOT recommended.
Read the link for more.
viewtopic.php?f=60&t=2228
You gave me just what I needed to know without thinking about it with no time before the gig and little time Saturday setting up...
Much appreciated
All the best
Saturday set up of DRPX went without hitch....huge help.
I used the rta to pink the monitors also to great success...even without any tweaking they sounded crisp and true...couldn't have been easier.
Thanks for your help to taking any thinking out of the setup for me...saved me time to to plug and play.
I'm going to sell on the DRPX and use my DRPA on monitors in future as I'm about to replace that with a PA2 for FOH...no doubt I'll be in touch again.
Thanks again
All the best
