Home dbx User Forum dbx Archive Threads DriveRack PA2
Martin Audio F1 System DriveRackPA2 Configuration
SissySissy Posts: 3
edited January 2016 in DriveRack PA2
Hi there!
I'm a new user and I need some help to setup the DRPA2 for my Martin Audio Sound system.
This is my system
4 loudspeaker Martin Audio F1 system https://martin-audio.com/downloads/data ... asheet.pdf
1 Sub-bass system Martin Audio WS218X https://martin-audio.com/downloads/data ... asheet.pdf
High Amp---> 2 YAMAHA P2500s
Low Amp----> 2 YAMAHA P5000s
Sub Amp ---->1 DAP AUDIO CX-3000
Mixer Pioneer
I need to improve it for dance DJ mixing.
I don't have a RTA mic.
Hope someone can help me.
Thanks in advance for answers.
Silvia
  • DraDra Posts: 3,777
    I assume you do not have the mx4? controller? I also assume that you are bi-amping the F1 package?
  • SissySissy Posts: 3
    Hi DRA!
    Thanks for your answer!
    Before I've bought DRPA2, I used MX5 (I still have it). And yes, I Bi-amplify my F1 sistem with YAMAHA P2500(high/Mids) and YAMAHA P 5000(Lows, but set up in DRPA2 as Mids.) In DRPA2 configuration I set up amplifing Lows ( my martin sub WS218X) with DAP AUDIO CX 3000.
    So I set up The DRPA2 as a 3ways sistem and sub... I set up XOVER frequencies as explained in the f1 sistem documents and limiters... It sounds very good... But I think it could sound better... I'd like to set up the subahrmomic sinth, and the PEQ... I don't know...
    Hope I explained my situation as well as you can understand it....
    Thanks in advance...
    Silvia
    Does it sound better with the Martin controller? It should. Have you considered using the Martin on one of the PA2's outputs as a full range controller? You'll still have the AFS, PEQ's and GEQ's, etc, for tweaking. I still used the Yorkville processor with my DR260 and will with my 360. My set-up is a zoned (multi-stage) set-up, and it gives me more outputs available.
