importance of data /specs ?
just some insider tip if possible.
got a 2nd hand kit of speakers,
fullrange + subs.
the subs are more or less the same bass module as the full-range, but just another box.
( like fullrange = 15" plus horn - sub = 15" - no horn)
Got no specs, have had no success finding any....
Though, for amps, looking at a couple of qsc gx3, so at least these will be known by the PA2.
The wizard of course, no issues setting it to full range + sub,
the amps = no worries either....
Just wondering if there's any real benefit/value to continue chasing info about the speaker to get the relevant data ?
fullrange + subs.
You can assume that it will be limited to 45 or 50 hz.
Conservative: 50hz BW18
Aggressive: 45hz BW18
Crossover: 100hz LR24
Only info found is;
http://www.deltecspeakers.co.uk/deltec_gx15.html
http://www.deltecspeakers.co.uk/deltec_bx16.html
Meaning the bx16 sub is simiply another 15" (same as the gx15) in its own enclosure....
