DRIVERACK PA PLUS SETTING FOR PRX 735 AND SRX828
djkarondjkaron Posts: 4
edited April 2016 in PA Configuration Wizard
Do anyone have the setting for prx 735 and srx828sp? If not how to manually setup a pa plus for the those speakers? also need the eq1,eq2 and eq3 settings..
IM NEW TO THE DRIVERACK.
THANK YOU
  • DraDra Posts: 3,777
    The EQ processing is already taken care of inside the speakers. You just need to set up a x-over point. 100hz LR24 should work just fine.
