Calculating cross-frequency & filter/slope
I m wondering if there is any reliable way to calculate the "right" cross-frequency and filter/slope (db/octave) of any woofer, based on thiele/small parameters (or even box parameters)...
If so, it would be great for cases as custom-made sub-woofers, e.t.c.
Speaker prediction software will only get you so far.
Another thing to remember is that it is best to apply filters (at x-over) at frequencies where the speaker / box is still flat at possible, so that the applied filter isn't being affected by any naturally occurring decline. That just complicates things.
Filter freq and slope calculations are too variable and would become too complex to predict, in my opinion. I know of no "if this and that, then this" database.
1. A common cross-frequency for subs is 100Hz (±20%).
2. By using Linkwitz-Riley filters (instead of Butterworth), you don't increase (+3db) the level around the crossover frequency (flat-crossing).
But, there are some other "rules" too, such as:
3. Rule of thumb says that a setting is usually "correct" when crosses a driver (woofer) over at double its resonant frequency (Fs).
4. Another rule of thumb for subs says that a Low Pass Filter (LPF) is necessary, exactly under resonant frequency (Fs) of a sub-woofer.
That's why I asked about thiele/small parameters and cross-settings based on them...
So, the conclusion till now is that there are no "rules" for calculating cross-frequency based on thiele/small parameters...
By the way, why are you using a BW filter (instead of LR) at the -3db spec point (or any other "lower" point)? And why 18db/octave?
viewforum.php?f=60
Lots of good stuff in the many articles. Driverack related and general sound questions answered as well.
Here is the direct link about why BW18.
viewtopic.php?f=60&t=1204
